how to compare different algorithms using graph in labview
i have designed a VI in which there are three different algorithms applied in case structure then common for loop is applied and at one time graph of selected algorithm is displayed.
 i want to run all the three algorithms simulataneously and display all graphs on single graph.
(3,056 Views)
you can change the enum array constant to an control and also pick the algorithm to compare...
Greetings from Germany
Henrik
LV since v3.1
(3,048 Views)
kindly send Compare VI in 2010 version. my all algorithms are going to single for loop which will run one at a time how i can compare all algorithms
(3,039 Views)
well, the picture should tell you all you need 😉
it took me 5 minutes to draw it ... redraw it made in close time 😉
or post your vi ....
Henrik
LV since v3.1
(3,032 Views)
If you want to compare all three at the same time, why would you even do something as silly as a case statement. That makes no sense.
(3,022 Views)
