how to change parameters of Static VI Reference
Can anyone let me know how to change the parameters of a static vi reference please? right now when I right click on it, just says "Strictly Typed VI". I don't know how to add/delete/change the parameters of it.
(3,274 Views)
The reference represents the connector pane of the SubVI. To change it you change the connector pane of the SunVI itself.
LabVIEW 2012
(3,265 Views)
Hi Steve,
Yes, I did that but the "Call By Reference" doesn't change and I don't know how to make it effect to the "Call By Reference Node". please let me know how. this is Source Distribution project.
(3,246 Views)
Accepted by topic author Triple_H
Hello Triple H,
This is Andrew Brown, an Applications Engineer with National Instruments. You will need to go through the process to create a new strictly typed VI reference in order to update the parameters of your Call by Reference Node. An article that details this process is Creating a Strictly Typed VI Reference That Calls VIs Dynamically
Please let me know if you have additional questions or issues in this area.
Andrew Brown
Software Engineer
(3,233 Views)
it works, thanks so much Andrew.
(3,218 Views)
