how to change color of intensity graph?
hello everyone...
                         I'm labview 7.1 user.. i'm doing one project where i need to use intensity gragh to show some data which is coming from a temperature sensor... and the sensor is on vechicle.... i want to use 6-7 colors for the scale...particular color for a particular range is it possible...? plz help...
(2,899 Views)
Hi RupaliG,
                  See the link below:-
                  http://digital.ni.com/public.nsf/allkb/1ADFF221E27F5B5886256E6F007C7B58
Thanks as kudos only:)
(2,890 Views)
Thanks... It really helped... now can you plz tell how can get scroll bars for X,Y n Z scale... i found scroll bar only for X scale... how can i get more than one z scale..?
(2,880 Views)
Hi RupaliG,
                 Try to add slide control and play with range property of the chart.Look at the attached example:-
                  Chart_WIth_Slide.zip 16 KB
(2,860 Views)
