Static variable in Formula Node
How do I declare and use a static int variable in a formula node?
Message 1 of 12
(5,924 Views)
Hi splee,
               You can look at Formulat node Syntax
Thanks as kudos only:)
Message 2 of 12
(5,919 Views)
Thanks but I can't find the "static" construct
Message 3 of 12
(5,913 Views)
Hi Splee,
               Control values are static if they are not wired to the connector pane, so you can write to them using a local variable
Message 4 of 12
(5,905 Views)
Hi Splee,
What you want to do and what do you mean by Static int variable? please explain your scenario
Message 5 of 12
(5,904 Views)
Basically I am using LabVIEW as a VI for my Vision Builder Automatic Inspection. VBAI is updating the Vi with : update_count. The update can happen anytime.
In the LV vi I want to keep track of how many times the update_count has happened. So it should start with 0, then 1, 2, 3, 4,..
I want to implement this using formula node..
Message 6 of 12
(5,900 Views)
.. and to make it more complicated, I want to be able to reset update_count if certain condition happens
Message 7 of 12
(5,898 Views)
@danil33 wrote:
Hi Splee,
Don't quite understand this.. can give just a very simple snippet?
Message 8 of 12
(5,895 Views)
Am not sure about the VBAI you mentioned but For updating the count don't you think shift register in a while loop and a case structure is sufficient?. Try to implement that way its very simple.
Message 9 of 12
(5,893 Views)
OK this is my code snippet, without using formula node.
I do not know how to:
- reset the feedback node in the first sequence to 0, if a certain event happens
- reset the feedback node in the second sequence to 0, if a certain event happens.
Thats why I thought of using formula node, and forget all the arrays and feedback node stuff... but I don't know how to use a static variable
Message 10 of 12
(5,888 Views)
