how to break up a library file into individual VIs
Is there a way to convert an llb file into a collection of individual VIs?
(2,595 Views)
Save with Options -> Developement Distro.
In the File Dialog then select: Use Directory.
Felix
(2,588 Views)
Accepted by topic author bracker
Another way: Tools->LLB Manager... open directory with library, point cursor to your llb (don't go inside of llb!), then right mouse click on llb and select Convert...
(2,581 Views)
Yes, thanks.  As you were writing your reply, I discovered this approach at the same time in the Labview help.  I couldn't figure out Felix's suggestion though--I didn't see where there was a "save with options" option.
Allan
(2,578 Views)
