Setting of spectrum
Hello All,
 With this code i am trying to set the spectrum( Centre freq, span, RBW, Video BW, sweep Time, amp). All this values i need to set automatically not manually. But when i ran this code, i am not getting req result. So just want to know my mistakes...
Thanks so much in advance...
Pallavi
(3,041 Views)
Are you getting a LabVIEW error? Are you getting an error from the instrument, are you getting and error on the instrument (some aren't sent back)?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,026 Views)
Hello All,
no error as such..... but spectrum is not getting set after running it.............
Pals
(3,018 Views)
With out the instrument in front of me I can't give you any specific advice. If you can make a simple vi that contains the "write" and error reporting vi (which is part of a library that isn't installed here), and cut and paste the various individual commands, starting with the left most. Run them one at a time and see if they set the instrument according to the values. Watch the instrument for any error messages. But without error message to show us, or an instrument of the same type here it is very difficult to know. Usually these are either there is an error in the command string, or that the instrument doesn't support some function being requested, but those result, at least with Agilent equipment, with a warning or other message on the the instrument.
Putnam
LabVIEW Champion
(3,013 Views)
Accepted by topic author Sim5
Hello All,
Its working fine..... Just u hv to take care for the commands...
Pals
(2,918 Views)
