how do you scale data to output to a daq
I am trying to output a waveform to a DAQ card, but am uncertian on how to convert the data to the necessary format (scaled data?). I am including a fragment. The data that goes to the chart is the same data that I want to place into a circular-buffered analog output application.
Thank you very much in advance. The responses to questions on this site have been extremely helpful in my learning of this environment.
(2,592 Views)
If you go into MAX and define a virtual channel and set the approriate scales,
You should be able to write your values to the virtual channel and let MAX do the conversion for you.
Ben
(2,592 Views)
