how do you get positional information from boolean arrays
Thanks so much for your help on this.  I have never really used this forum before, but it is AWESOME!
You guys are the best!
Brian
Message 21 of 31
(2,945 Views)
Hi Again Everyone,
thank you for your help on this, I now have a working prototype.
I do have another question though....
Is there any way to make labview draw the image of a round soccer ball on the net other than just drawing the colored circle?
I figured out how to overlay an image but the image is always square.  If I could fill the drawn circle with an image instead of a solid color it would be great!
Thanks in advance....
Brian
Message 22 of 31
(2,817 Views)
Since we are dealing with a picture, you have full control over every single pixel and you can draw anything you want. Just requires a bit more code. Also don't forget the "mask" input.
Message 23 of 31
(2,810 Views)
Or you can customize a boolean control with a picture. You can make it visible or not and position it where you want. Attached is a quick example, I edited a picture with GIMP and customized a flat round button from the classic, boolean palette.
Ben64
Message 24 of 31
(2,798 Views)
Hi Guys,
That is cool....i saw something on how to do this...
but,  I think what I really need is just a round .jpg that I can read in and draw onto the net image....
Brian
Message 25 of 31
(2,780 Views)
OK, here's a quick rewrite using the mask input. See if this works for you.
Message 26 of 31
(2,775 Views)
Man, you are awesome!
Thank you so much!
Message 27 of 31
(2,750 Views)
I have been watching tutorials to see how you drew thw ball and can't figure it out....
Message 28 of 31
(2,733 Views)
Use Read PNG File.vi (or Read JPEG, Read BMP depending on the image encoding), browse to the image file and after running the vi right-click on the image data indicator and select create constant.
Ben64
Message 29 of 31
(2,725 Views)
oh, i think i see....this was done once but now I can't see the image it was created from ....right?
thanks
Message 30 of 31
(2,721 Views)
