how do i setup a control table using a single input
I am a very newbie LabView user.    I am trying to build a control component using a single 4 position input (a dial (0 thru 3) that outputs a 4 bit result based on the input.    What control do I need to use?
The table looks like this:
inputs        |outputs
4HOpenOpenOpenGround
2HGroundOpenGroundGround
NGroundGroundGroundOpen
4LGroundGroundOpenOpen
Eric Yuzon
Senior engineer
ERC
Walled Lake, MI 48390
ericyuzon@e-reman.com
e-reman.com
(3,909 Views)
Eric, please look at the attached VI.
Is this what you would like?
In my example True=Open and False=Ground
Message Edited by Cory K on 06-14-2010 11:17 AM
Cory K
(3,899 Views)
Awesome, almost there!   How do I then change those levels so it is digital?  (open = 12 volts, ground = 0)
Eric Yuzon
Senior engineer
ERC
e-reman.com
(3,890 Views)
That would depend on your hardware.
What hardware are you using?
You could use the "DAQmx Write" function in this palette:
 Measurement I/O >> DAQmx - Data Aquisition
Cory K
(3,880 Views)
Accepted by topic author bteed@dormanproducts.com
I'm not there yet.  I'm still using the evaluation software.   I can worry about that when I get the hardware.   This will work for now!  Thanks!
Eric Yuzon
Senior engineer
ERC
e-reman.com
(3,867 Views)
