Error while trying to install Labview statechart module
I have Labview 2009 SP1 installed on my computer (Win 7 64 bits). When I  try to install the statechart module I recieve the following:
"Labview 2009 is not detected" and the installation terminate.
Please advice.
Regards
Gabi
(3,672 Views)
Are you using 64-bit or 32-bit LabVIEW?  I don't think all toolkits have been compiled to work with LV 64-bit as of yet.  I'm sure someone else can confirm my statement or correct me if I'm wrong.
(3,645 Views)
Hope this might help you somewhat.
(3,635 Views)
As far as I know Labview 2009 if fully compatible with Windows 7 64 bits as well as all the Labview modules. Am I wrong?
(3,622 Views)
gabi_hor,
Check out the LabVIEW 64-Bit vs. 32-Bit Applications FAQ, specfically the following question:
"Q. Which LabVIEW modules and toolkits are available for LabVIEW 64-bit?
A. The NI Vision Module is the only module available for LabVIEW 64-bit as of LabVIEW 2009. Any other modules and toolkits must be run using LabVIEW 32-bit.
Ben Sisney
FlexRIO V&V Engineer
(3,604 Views)
