how do i create a sub vi
hi
can any one please tell me how to create a sub vi
thanks
(3,246 Views)
Creating a subvi's is just like creating a vi.
Chapter 2 of the LabVIEW User Manual gives some valuable info on that.
Another option is to select the code you want to "sub-vi". Select under "edit" "create subvi" and voila, your subvi.
(3,246 Views)
If your creating one from parts of a diagram, just drag a rectangle to
enclose what you want, uner FILE select create sub-vi.
Else, just write it as any vi and use it in another vi.
On Mon, 11 Mar 2002 00:30:07 -0800 (PST), PdB_Serenity_nl
(3,246 Views)
Make a new Vi (your subVi), go to the Hierarchy window, drag your new Vi into the diagram of your main Vi. Link it by right-clicking the icon in the top right corner of the front panel, choose "show connector." Click on the fields and link them. You might need to right click the subVi icon in the main Vi and choose "Relink to subVi" if you change the connectors.
(3,246 Views)
