Application Builder and thread settings
Hello everybody,
I have created a VI which uses multithreading. Necessary was for me to set the threading properties of the LabView by running the threadconfig.vi tool. This tool wrote a line into the Labview config ini file (LabView.ini in LabView 6 directory). My program worked fine, then I wanted to compile it to exe version using Application Builder. I did it but now exe file doesn't work with threads. Seems the parameters which were set to LabView ini file doesn't present in exe file. And my question is: how can I set the same thread properties to exe file, like it is in LabView environement?
TIA,
Yazilim.
(2,733 Views)
Each exe has its own ini file. Try making the changes there.
(2,733 Views)
