how do I programmatically edit items in a Text Ring inside a cluster
I have a text ring inside a cluster array that I would like to change programmatically.  I know how to change the text strings in a ring when the ring control is not inside the cluster.
Message 1 of 12
(7,367 Views)
From the FP pop-up on the ring (just the ring!) and select create property node.
Ben
Message 2 of 12
(7,362 Views)
And for the more generic solution, you can get a reference to the controls inside a cluster by using the cluster's Controls[] property.
The order of the references is the tabbing order and you can use the To More Specific Class function to cast the reference to your target class.
___________________
Try to take over the world!
Message 3 of 12
(7,356 Views)
And you can check the Label.Text property to be sure you got the correct item in the cluster!
Message 4 of 12
(7,345 Views)
But is there a way to directly get ring item text for rings in an array without converting to cluster per below code:
Message 5 of 12
(6,876 Views)
But you do have to be careful with this. If the label changes, the code no longer finds the reference. I prefer Ben's method (not the one listed above Smiley Surprised) of bundling all references into a cluster in an action engine, or a gui manager. I then create a new action for each different gui management action I want to take. The looping through references is definitely a quicker solution, but I like having a cluster with the explicit names of the references, to force any other developers (or myself) to explicitly unbundle the reference they want to use.
Message 6 of 12
(6,872 Views)
Note that when I created the VI snippet, the reference name changed from 'cluster' to 'cluster 2'.  VI snippet must not have been able to determine that the reference was from the cluster.
Message 7 of 12
(6,860 Views)
If you right click on your array and click Create»Property Node»Ring Text»Text then you shouldn't have convert to a cluster. If you read a string from this property node, it will give you string value of whatever array index is selected.
Message 8 of 12
(6,836 Views)
If you right-click on the array ELEMENT, you can create a property node to get ring text.  However, you can create a similar property node for the ARRAY of menu rings.   As you can see below, there is no way to get ring text in this case.
Message 9 of 12
(6,816 Views)
Oh yeah -- sorry about that DonRoth. I understand better what you're trying to do now. I can see how you would prefer not to create a property node for each element in the array.
Message 10 of 12
(6,788 Views)
