how do I find the image type of an image file
This was posted on the LabView forum in error yesterday,  Please excuse the dual post.
I am trying to open a JPEG image.  If I do not know the image type (8U, 16I, GrayscaleSingle, ... etc)... is there a way to find out that information?
If you open the file using IMAQ ReadFile...you have to supply a Create Image input to allocate space...the input specifies a type to read...but if the type of the stored data is not the type specified in the read file you either read the file as the type specified, or the file does not produce any values...(and no error is produced).
Examples:
Store a JPEG as a Single Percision Floating point image.
Use a Creat File to specify that the file is read with the following types...with the following results
Type Specified        Type Read         Resulting image
U8                               U8                     8 bit image appears
16I                               16I
(3,074 Views)
duplicate post
Please continue in other thread.
(3,072 Views)
Accepted by Hummer1
Hummer1,
There are two methods to accomplish this:
1) IMAQ GetFileInfo, which has quite a few outputs involving the image details.
2) Read JPEG File, which you can unbundle the image data output to get the image depth, or other attributes.
I would reccomend the IMAQ function, due to it being more detailed.
Hope this helps
Chris Van Horn
Applications Engineer
(3,046 Views)
that's perfect...
I didn't see that...thanks for the tip.
Sometimes the simple and straightforward hides in the fog of diversity and capable.
Humming once again.
(3,037 Views)
