Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
how can i write this C-Code in G-Code
hallo
how can I write this C-Code in LabVIew ,
for a=0; a=<10; a++
   for b=0; b=5 ; b+2
        X= 3+b;
  Y=1+a;
please see the attachment and tell me where is the problem
Message 1 of 8
(3,753 Views)
I can't open 8.5, but I would suggest you use a For Loop
Message Edited by JeffOverton on 02-28-2008 11:53 AM
Message 2 of 8
(3,739 Views)
Well, at least you tried and got some of it right. Smiley Happy
I think this should do what you want, but my C is rusty. Is the increment performed before or after the loop executes? If it's after, then I believe the loop should iterate 11 times, not 10.
In any case, you should note that for a literal translation, you would need to add a sequence structure to guarantee that Y was written to only after the inner loop finished because of the way data-flow works.. Also, note that controls and indicators in LabVIEW are not equivalent to variables. They can be used as such, but they usually should not be.
Another point about this is that you probably want to use the correct data type - the orange terminals are floating point indicators (of double precision, in this case) and you want integers.
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
___________________
Try to take over the world!
Message 3 of 8
(3,710 Views)
tst, that would give you b=0,2,4
Message 4 of 8
(3,707 Views)
Which I believe is correct, since b is initialized to 0 and the increment is b+2.
Isn't C a great language? Smiley Very Happy
___________________
Message 5 of 8
(3,704 Views)
Oh man, I knew there was a reason I switched out of comp sci after intro C++Smiley Tongue
Message 6 of 8
(3,702 Views)
Although, then I don't understand how you can get to b=5.
I guess you can consider me confused. Smiley Indifferent
___________________
Message 7 of 8
(3,701 Views)
Ok, so I wasn't as bad as I thought.
Message 8 of 8
(3,699 Views)
