Thank you for replying.
This is a my second NI PXI system, the first system also had a slow transfer rate. But the rate is a bigger problem with this second system because there is a lot more data to transfer, about 20+ GBytes. Right now I am in the process of transferring 10 files of about 10 GB. I started the transfer and went to lunch, it should take a couple of hours.
chassis : PXI-1056
controller : 8196
connection : PXI - PC via crossover cable.
LAN speed : Gbit
OS : Labview RT to Windows XP
Transfer program : Filezilla, (other methods produce the same result)
I have transfered similar size files from PC-PC and obtained a rate of about 33MB/sec vs 2-3MB/sec
In previous forum posts there was mention of setting the transfer mode to full duplex. On the PXI side, using MAX there is a drop down list to switch to Gbit full duplex, but these options aren't enabled. The only choice available is auto detect.
On the PC I set the transfer mode to Gbit full duplex. The change made no diffference.
Dave
