02-08-2014 12:13 AM
02-08-2014 01:24 AM
02-08-2014 01:25 AM
You did not attach anything, but you can change the display format of any indicator (or control) to suit your needs.
You did not attach anything. How are you displaying the value?
02-08-2014 03:19 AM
02-08-2014 03:21 AM
02-08-2014 03:43 AM
Hi redsna,
maybe you have the same problem as others describe here. Seems to be hard for Lithium to support FireFox, but you will find workarounds following that link…
02-08-2014 03:50 AM
this is attached
02-08-2014 10:51 AM
Please explain which indicator is giving you trouble.
02-08-2014 08:22 PM
Y in waveform data (step6)
Thank you
02-08-2014 09:48 PM
The waveform Y is DBL, so it internally has plenty of resolution. The number of displayed digits is just a cosmetic property and can be freely chosen.
How do you tell that the resolution is less? I cannot tell from the VI you have attached. If you want more digits showing on the Y scale of the graph, just change the formatting.
