how can i generate only one period of sine wave
how can i generate only one period of sine wave ?
Message 1 of 13
(10,725 Views)
You can use sine wave.vi or simulate signal vi
Message 2 of 13
(10,713 Views)
18629i6A0F9ED56EBCCCFA
Message 3 of 13
(10,700 Views)
Just specifying the frequency does not allow you to generate a single period. Just look what happens if you ask for a 2Hz signal. You need also specify the number of samples and sample rate.
Message 4 of 13
(10,682 Views)
You can manipulate the sampling info with the desired frequency in several ways to keep just 1 period.  See pic for a simple example.
EDIT:  You have to have the sampling frequency (Fs) equal to the number of samples (#s)
...  Nevermind, tbob beat me to it.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 5 of 13
(10,670 Views)
Dennis is correct.  The reason Muks example seemed to work is because the default sample rate is 1000 and he used a frequency of 1Hz.  To get one cycle at any frequency, multiply the frequency by 1000 and set the sample rate to this number.  There is a cluster on the bottom of the Sine Wave funtion that allows one to set this parameter.
18643i8E25D4EC8FB26608
- tbob
Inventor of the WORM Global
Message 6 of 13
(10,667 Views)
I'm using this method that you discribe for generating a sine wave with one cycle.
Then I send this sine pulse to my soundcard. Works perfectly for a low frequency.
But I need a frequency of 10kHz and then this VI doesn't work.
But normally my soundcard works till 30 a 35kHz (For example when I make a continous sine wave)
Does anyone has a solution for this?
Thanks!
jelle
Message 7 of 13
(10,114 Views)
One cycle of a 10 kHz sine wave is only 100 us in duration.  I'm no biologist (or is it electrophysiologist?), nor do I work much with sound in general, but I did read wikipedia's Loudness article--I wouldn't expect the human ear to be able to pick this up.
Best Regards,
John Passiak
Message 8 of 13
(10,108 Views)
That's no problem. I don't have to hear it.
I send it with my soundcard to a pc oscilloscope an i just want to see it on my pc oscilloscope.
Problem is that the VI blocks if I use high frequencies...
Any labview solutions?
kind regards
Message 9 of 13
(10,074 Views)
If you generate the signal as an array you should be able to play it with play sound.
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 13
(10,062 Views)
