how can i build a manchester coding in labview signal processing?
As Stated- all you need is a clock and data.  the clock rate needs to be twice the data rate. and and XOR
In this example (please don't tell that I used express vi's)  Data and Clock are simulated 1 Amplitude square waves (atternating between 1 or -1 unit)  This makes the Multiply function equivallent to XOR. and is a representation of true manchester encoding since Manchester signals are never T or F they are Pos or Neg with the transition representing a logic state.
"Should be" isn't "Is" -Jay
Message 11 of 16
(3,460 Views)
@idma wrote:
work done by me uptil quantization.....after this i have to implement line coding!!!
help reqiured
regards
Great- all you need is a clock and then normalize your data waveform.  multiply the clock by the data and your there
Message 12 of 16
(3,454 Views)
Jeff,
Thanks for the code, that may provide a better understanding. I appreciate the help kudos to you! +1
HowEVER -1 kudos for Express VIs 🙂
thanks
Sam S
Message 13 of 16
(3,452 Views)
I thought you blue bars liked those x-vi's  Isn't that why I have to edit my palatte settings to do anything useful with LabVIEW?Smiley Very Happy
Spoiler
I HAD TO BUILD IT TWICE THOUGH! Smiley Mad  See the attachment to find out what happens when you try to create a snippet of that codeSmiley Surprised
Message 14 of 16
(3,448 Views)
hahaha well played sir well played,
I actually prefer not to use them but they have there place (sometimes) Smiley Very Happy
Sam S
Message 15 of 16
(3,444 Views)
thanx Jeff and Samuel 🙂
Message 16 of 16
(3,432 Views)
