How to set parameter to be positive in curve fitting
Dear all
I am using "curve fitting "  VI to fit my experiment data.
The nonlinear model  is  y=0.5642*(1+b*(2*(x-c)^2-1))*exp(-((x-c)^2)), where "b" and "c" are two parameters.
 After fitting, the parameter "b" sometimes is negative. But I need to set "b" only to be a positive number. However, there is no such option in the curve fitting VI,   as shown in the  attached figure.
How can I realize this?
Any expert can help me? Thank you very much in advance!
(5,288 Views)
Put an absolute value on the output for b from the curve fit.
Tim
GHSP
(5,283 Views)
Accepted by topic author ereerre
Substitute b=exp(d) into your equation: y=0.5642*(1+exp(d)*(2*(x-c)^2-1))*exp(-((x-c)^2))
Fit for d and c, then calculate b=exp(d).   The program can fit d positive or negative while b is alway positive.
-- James
(5,276 Views)
Many thanks to aeastet!
 I have tried, but I can not put an absolute value on the output for parameters in  "curve fitting" VI
There is no such option in the setting of the VI.
If I use  y=0.5642*(1+abs(b)*(2*(x-c)^2-1))*exp(-((x-c)^2)), it was prompted that the grammar was wrong.
 Also many thanks to  drjdpowell !
Your suggestion really works.
Thank you so  much for your kind help!
(5,258 Views)
By the way, you can extend this to put different constraints on b than b>0:
b > m    -->   use b = m + exp(d)
b < n     -->   use b = n - exp(d)
and for both high and low limits you can make use of the arctan function that is always between -pi/2 and +pi/2:
m < b < n    -->   use b = m + (n-m)(atan(d) + pi/2)/pi
-- James
(5,242 Views)
