how can I save the data from Labview FPGA
  • I had only learned labview for several weeks, because I need to use 1MS/s to generate the sine wave and receive the signal for 400kS/s and save the data for 5 minutes.
  • As I know labview real-time (RT) only work for 1kHz for a loop, so need to use the FPGA to generate the signal, but the problem is how can I create the file and save the data?
  • I need to save the generate the signal and receive the data at the same time and save the hole data as much as possible.
  • As the NI9222 example code, it made FPGA to receive the data and show the wave in RT chart, but that will lose too many data so I can’t analyze it.
(2,773 Views)
Accepted by topic author styilee
you need to do all file access in the RT host, the FPGA cannot do that.
There are example projects explaining how to transfer data from/to FPGA, even at high sample rates...
(2,750 Views)
Dear GerdW :
I'm appreciate for your answer.
That means I can only save the analyzed data in RT.
And try to use another way to proof the data is reasonable....   Smiley Frustrated
(2,745 Views)
