03-06-2013 10:25 AM
XY graphs accept complex arrays in LabVIEW 2011 (and even earlier), in which case they graph IM vs RE. Why are you rebuilding the VI?
Also, are you sure that the array is wired across in the other cases?
If you have a problem with a rebuilt VI, please attach it once more so we can see what went wrong. Thanks.
03-06-2013 09:42 PM
The VI works fine
03-09-2013 04:09 AM
the solution works fine . But when I run for a long time the graph vanished without keeping any history. I don't understand what is the reason, the progam is in running mode also. Please help me kindly
03-09-2013 01:41 PM
How long is "a long time (minutes, hours, days, weeks, months...). how much data is in the shift register when the data "vanishes".? Could it be that you are running out of memory?
The graph itself does not keep any history, the history in in the shift register. Of course you will also run in performance problems if you try to graph billions of points.
Please explain exactly what yo observe. Are you really sure that the array is wired across all other cases of the case structure?
If you have mande modifications to the program, please show us the latest version.
03-09-2013 10:26 PM
yes its wired well. But when it reaches around 300000 counts the graph vanished completly the program runs fine. Is there anything to do with shift register?
