how can I extract a gaussian function out of a spectrum which has five gaussain functions....
Just for completeness, heres how you would fit the data using the general linear filt, which assumes that only the amplitudes are unknown.
(There was a formula error in my previous version, whcih I have corrected above).
Also here, you can add more gaussians by simply adding rows to the array of clusters. As you can see, the fit is not great.
I also show the component spectra.
Message 21 of 29
(3,179 Views)
That is perfectly working now. Thank you very much. but is it possible to plot `data, best fit, the final gauss functions and original spectrum minus final gauss functions`` rather than ``data, best fit and guess´` ?
Message 22 of 29
(3,161 Views)
Yes, everything is possible.
Message 23 of 29
(3,154 Views)
Try this:
Message 24 of 29
(3,141 Views)
Just on a sidenote, notice that my gaussians are normalized for unit height, independent of width. It would typically be more reasonable to normalize for unit area. It would be trivial to adjust the model function accordingly.
Message 25 of 29
(3,074 Views)
would it be possible to convert your multiple gaussian fit vi to labview version 9.0.1.
Unfortunately i'm not able to open it.
Thanks in advance.
Message 26 of 29
(3,031 Views)
Try this...
Message 27 of 29
(3,022 Views)
Unfortunately i receive an error code 3 concerning a problem while frontpanel is loaded.
Can you help ?
Message 28 of 29
(3,016 Views)
Sorry, I have no way of testing the downconverted VI in LV2009. Also error 3 seems very odd. Did you extract the zip file first?
What is the full error message?
Here's another save, this time with slightly different options. See if this works better....
Message 29 of 29
(3,010 Views)
