annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
how can I extract a gaussian function out of a spectrum which has five gaussain functions....
Just for completeness, heres how you would fit the data using the general linear filt, which assumes that only the amplitudes are unknown.
(There was a formula error in my previous version, whcih I have corrected above).
Also here, you can add more gaussians by simply adding rows to the array of clusters. As you can see, the fit is not great.
I also show the component spectra.
Scarica tutti
Messaggio 21 di 29
3.182Visualizzazioni
That is perfectly working now. Thank you very much. but is it possible to plot `data, best fit, the final gauss functions and original spectrum minus final gauss functions`` rather than ``data, best fit and guess´` ?
Messaggio 22 di 29
3.164Visualizzazioni
Yes, everything is possible.
Messaggio 23 di 29
3.157Visualizzazioni
Try this:
Scarica tutti
Messaggio 24 di 29
3.144Visualizzazioni
Just on a sidenote, notice that my gaussians are normalized for unit height, independent of width. It would typically be more reasonable to normalize for unit area. It would be trivial to adjust the model function accordingly.
Messaggio 25 di 29
3.077Visualizzazioni
would it be possible to convert your multiple gaussian fit vi to labview version 9.0.1.
Unfortunately i'm not able to open it.
Thanks in advance.
Messaggio 26 di 29
3.034Visualizzazioni
Try this...
Messaggio 27 di 29
3.025Visualizzazioni
Unfortunately i receive an error code 3 concerning a problem while frontpanel is loaded.
Can you help ?
Messaggio 28 di 29
3.019Visualizzazioni
Sorry, I have no way of testing the downconverted VI in LV2009. Also error 3 seems very odd. Did you extract the zip file first?
What is the full error message?
Here's another save, this time with slightly different options. See if this works better....
Messaggio 29 di 29
3.013Visualizzazioni
