how can I do the conversion from a string to a float
I need to take a string, which is the time and to convert it into a float, because the program I send it to is only receiving a float...how can I do that?
Message 1 of 18
(3,977 Views)
In the strings-palette, there's a subpalette called "String/Number"-conversion...Just use Fract/Exp-String to Number to convert your string
Greetings
Christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
Message 2 of 18
(3,975 Views)
It may not be as simple as that. Is the string simply the float value as a string (in which case you can do the above), or is it in a specific format?
Message 3 of 18
(3,968 Views)
let me explain, if the time is the string 18;30;36 I want the float 183036 kind of
Message 4 of 18
(3,964 Views)
well assuming the time is broken up by semicolons as you have shown,
first, split up the time, using ";" as your split character.
then, you have three segments: hours, minutes, seconds.
Then i would convert each of those (using string --> dbl or something like that)
Then you have 3 numbers to do whatever you would like with.
Cory K
Message 5 of 18
(3,959 Views)
Cory K
Message 6 of 18
(3,958 Views)
There can be different approaches, just two of them: Use Scan from String to get the different parts of your string as Number or eliminate your ;;; from your string with "Search and replace string"...
Greetings, Christian
Message Edited by cschneider on 08-07-2008 11:13 PM
THINK G!! 😉
Message 7 of 18
(3,948 Views)
Heres the program that I was describing earlier (and accidentally posted twice oops)
Cory K
Message 8 of 18
(3,942 Views)
Scan From String is a lot easier, don't you think? Smiley Wink
Message 9 of 18
(3,934 Views)
My contribution to the conversions...gives you a 1D array of 3 elements (one for each section of the string).
Message Edited by corys on 08-07-2008 03:14 PM
-Cory
Message 10 of 18
(3,928 Views)
