how can I control application
Hi
I have quastion
My manager gave me application which is built in software but not labview , he has asked me to control this application using labview , please is there is anyone know which function I should use and how ??
Please waiting your replay:womansad:
(3,331 Views)
That totally depends on the other application. Does it have an ActiveX interface or some other api?
(3,317 Views)
yea , it is have active intervase , it is called IPVC 3
(3,312 Views)
Then you will need the documentation on that from the vendor. You will use it's properties and methods for interfacing. You can get a general idea of how ActiveX is used by looking at the Excel examples but since each ActiveX interface is different, you will have to work out the details yourself.
(3,304 Views)
you mean I should contact the person who designed this program so I can use its proprites to control it using Labview???
(3,301 Views)
Yes
(3,295 Views)
(3,293 Views)
