histogram with just some columns of a table
sorry,i forget.i did it now
Message 11 of 19
(1,557 Views)
bump
Message 12 of 19
(1,540 Views)
@altenbach wrote:
  • You still have not explained what kind of histogram you want from ll the columns. Explain exactly want kind of result you would expect from the default data.
Message 13 of 19
(1,532 Views)
like that one,but the green also has to appear there in E1.....,why i can't see it
i made some change on the vi
Message 14 of 19
(1,528 Views)
Message 15 of 19
(1,524 Views)
Accepted by topic author achfire
OK, so you just want a bargraph with two bars per x value. that has nothing to do with a histogram. See my confusion? (A histogram is a statistical tool for data reduction. You are graphing all the raw data)
Your code was way too convoluted and inefficient, so here's a quick rewrite. See if it can point you in the right direction. As I said, I don't have your office toolkit, so I added a listbox to select a candidate and graph the result. You can leave that code out). All your file operations belong into the FOR loop in the upper right.
Notes on your code:
  • You are calculating the averages N times. It is sufficient to do that once in a seperate loop.
  • Why do you need two identical array diagram constants. One is sufficient. Branch the wire.
  • Building an array with one row, transpose it into an array with one column, then indexing out selected columns seems convoluted. Simply leave it as a 1D array and index out elements. same difference!
  • One of your inner loop does absolutely nothing.
Message 16 of 19
(1,516 Views)
so this code will work with excel,a histogram is a bar graph i think
i'll try it now
Message 17 of 19
(1,506 Views)
A histogram is a very special kind of bar graph where the Y value is a count and x is an observation range.
You data has nothing to do with a histogram.
Message 18 of 19
(1,499 Views)
thanks a lot it really works,ur amazing Mr altenbach Smiley Wink
Message 19 of 19
(1,485 Views)
