histogram in DSP module
I am trying to do a histogram in LabView DSP module. First, is it possible? If so can it be done? Any advice would greatly be appreciated.
(3,503 Views)
Here is the help document for the Histogram VI. It is located under Mathematics » Probability and Statistics.
Amanda Howard
Americas Services and Support Recruiting Manager
(3,488 Views)
Thanks, but does it work when I use the Speedy-33 as my target? When I do, I don't see the probability option in mathematics. Just the numeric options and special functions option.
(3,483 Views)
Are you using a digital encoder? This Developer Zone article describes how to develop a histogram using the Speedy-33 and DSP module.
Amanda Howard
(3,471 Views)
Thank you so much. The power spectrum vi worked. Only one problem remains, saving that data to a file preferably a worksheet. Thanks again for the tip, any further advice would be appreciated.
(3,462 Views)
There are great examples of File I/O in our Example Finder, accessed at Help»Find Examples. Expand the Fundamentals tab, then the File Input and Output tab, and choose an example that works for your application. "Write to Text File" is a great place to start. Implementing this into your existing code or vice versa should allow you to accomplish your goals. Happy coding!
Amanda Howard
(3,451 Views)
