Ring controller
hi i am use the one ring controler in my application ,here i am channging the user view of stings using sting property dynamically.In my programme three frames are there this also a enum controler. when frame  1 is selected  dynamic stings assign to (example (1 to 7)).
when frame 2 click on enum controller the dynamic strings of the ring controller assign to(1 to 10) dynamically. my problem is after selecting frame 2 , select the ringcontorller(8 or 9or 10),when change the enum controller to frame 1, the ring controller shows (8 or 9 or 10). wtih out click on the ring controller which or not present the case frame 1. when click the ring controller the selecting values shows the correct(1 to 7) out side , in the ring controller indicating   8 or 9 or 10..i expect soluation is when click frame 1 .the ring controller not shows (8 or 9 or 10). how to do that one.give logic.
(2,830 Views)
The description of your problem is very difficult to read making it hard to understand what you are trying to do.  Can you post a VI demonstrating what you are talking about?
(2,807 Views)
Hello Rabili,
Would you be able to show an image or example vi of what you are describing?
Juan Galindo
(2,744 Views)
