histogram bug??
I have a weird result from histogram to ask your help.
Simply, I find Histogram uses the     (range_min: range_max] and     [range_min: range_max) dynamically.
Attached is the test vi. Inside the program, the histogram is from 0:1 with 10 bins. The result will be changed when a number changed from 0.9 to 0.91, while it stays constant when changed between 0.2, 0.21.
(3,758 Views)
This looks fine to me. If a value falls right between the boundary of two bins, a decision needs to be made based on established statistical procedures.
You can open the front panel of the express VI and see what histogram index is calculated for each value:
Value 0.20: Fractional Index: 1.50000000000000000 -> rounded to bin index 2
Value 0.21: Fractional Index: 1.59999999999999964 -> rounded to bin index 2
Value 0.90: Fractional Index: 8.50000000000000000 -> rounded to bin index 8
Value 0.91, Fractional Index: 8.59999999999999964 -> rounded to bin index 9
LabVIEW just follows the standard Nearest_integer_function where half-integers are always rounded to even numbers. This is statistically correct. Nothing wrong with that. 🙂
(3,752 Views)
Altenbach do you ever sleep?
... And here's where I keep assorted lengths of wires...
(3,748 Views)
altenbach people say that you know a lot of picture controls, any advice that you could pass on? check http://forums.ni.com/ni/board/message?board.id=170&message.id=244538
_____________________________________________________________________________________________
Dude LabView rocks.
(3,740 Views)
Thanks. It is right within its way. But it is a little out of my common sense.
(3,726 Views)
