why does the waveform generator reset every time?
  I'm an extreme noob, like today, but I do have some experience with other DAQ software such as Dspace.  I'm trying to use Sawtooth Waveform.vi.  When I change frequency and amplitude then close that VI and go back to my block diagram and run it, the frequency and amplitude are still the defaults.  I don't know how to save the changes when I make them.  The "save" option on the menu is grayed out, and choosing "save all" does not seem to help.  I'm using version 8.2.1.
Brett
(2,730 Views)
To save control values, go to Options>Make Current Values Default. Then save the VI. Hoever, it is not a good idea to do whis with one of the shipping VIs unless you save it in a new location and with a different name. Instead, create a VI that calls Sawtooth Waveform and either create controls for it on the front panel of your VI or add constants on the block diagram. You really need to spend a bit of time learning some of the LabVIEW basics. A good place to start for with some free tutorials is at http://www.ni.com/academic/lv_training/how_learn_lv.htm.
(2,725 Views)
Dennis,
  Your message was a big help.  Although I had figured out controls and constants (in a simplistic sense), it seemed like one should be able to change the vi values.  After seeing your note, I just used constants, and everything's good.
(2,721 Views)
