highlight execution speed up
Hi Visual Programming Champions!
Im working on a School project, I'm doing an Espresso vending machine.
Anyways.... I'm just wondering if there is a way to speed up the highlight execution run?
I just need it to be a bit faster.....
Thanks for your answer.  If I get a satisfying answer, i'll send you a drawing of a seven legged spider.
Alex Tressapos
Message 1 of 10
(9,572 Views)
Accepted by topic author Tressapos
That request has been popping up regularly since I started coding in LabVIEW.
In fat I'd like a speed control that wolud also let me go back in time to review what I just missed. But sadly that is not possilbe (yet).
The best i can do is suggest you set a break-point after teh boring stuff but before the part you are interested in.
I sure wish I could have given a better reply.
Have fun!
Ben
Message 2 of 10
(9,567 Views)
Give the vi a few cups of Expresso, that should speed it up 🙂
Message 3 of 10
(9,548 Views)
Just write your code correctly the first time and you wont have a problem...haha I kid. There's nothing you can do. But as far as your program goes have a look at this
http://zone.ni.com/devzone/cda/tut/p/id/6194
it is a vending machine example and may give you an idea of how to at least set everything up with a state machine. Take it or leave it but I saw your assigned problem, thought of this example, and I just thought if you have troubles with the actual coding that it may help.
Message 4 of 10
(9,533 Views)
seven-legged spider
Paid in full.
Jim
Message 5 of 10
(9,523 Views)
That was really helpful, now I only need 1000 dlls to buy
the State chart module. I'm currently using the Student Version and it is not
included. (sad)By the way, the spider that jcarmody attached, is not the
original. Mine has missing a different leg. Thanks for your fast answer. This
will help me finish my school project in time (today).
Alex Tressapos
Labview proven noob
Message 6 of 10
(9,515 Views)
There's a wonderful state machine template that JKI made available here.  They have some good resources there to get you started, and you don't need the statechart module Smiley Wink
Jim
Message 7 of 10
(9,510 Views)
the State chart module....By the way, the spider that jcarmody attached, is not the
original. Mine has missing a different leg. Thanks for your fast answer. ... finish my school project in time (today).
Alex Tressapos
Labview proven noob
You are welcome.
Re: SC Module.
The learning curve for that widget is more than a day so it would not help you anyway.
Re: Spider
That's OK. I prefer Kodus to spiders any day, and on top of that you marked my reply as a solution! Hell, I'd rip the legs off of ten spiders to get one of those.
Thank you!
Ben
Message Edited by Ben on 11-26-2008 12:18 PM
Message 8 of 10
(9,501 Views)
There is 100's to 1000's of dlls all over the windows system directory.  Perhaps you can exchange them for the State chart module. Smiley Very Happy
Message 9 of 10
(9,499 Views)
hahaha...
I'll then send a zip file with most of my windows/system32/ directory,
and see if NI will send the module back.
Thanks for the laugh.
I'll post my work when i'm done, Im sure you guys could have made it better.
Alex Tressapos
Labview noob.
Greetings from Mexico
Message 10 of 10
(9,494 Views)
