hide edges on indicator?
Hi
anyone knows how to get an indicator, numeric or string, showing only its text, without any fancy 3D edges around it?
I tried making it transparent but that doesn't work, also in properties I can't find anything relating to it..
I just want a piece of text displaying on the fp, shouldn't be hard??
(2,633 Views)
Look in 'Classic Controls' palette. In both the numeric and string sub palettes, there is a control called a 'Simple Numeric' and 'Simple String'.
Both of these can be easily made completely transparent using the coloring tool.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,633 Views)
When you change the color, try the tab key. This switches between the
background and foreground color.
You can also begin with an indicator from the "clasic controls". Some of
them are very simple, e.g. only a white rectangle with a black line
surrounding it. Both colors can be changed (also to transparant).
Wiebe.
"stino" wrote in message
news:50650000000800000025E30000-1079395200000@exchange.ni.com...
> Hi
(2,633 Views)
thanks for both answers, problem solved, next time I'll search deeper in the palettes..
(2,633 Views)
