Help creating buffer
Hello, I am using a PCI 6110 S Series card (5MS/sec).
I need to stream data @ 5Mhz for 1.5 seconds (7,500,000 data points). I am using hardware timing. The problem I am running into is the buffer on the card is filling long before I get my points. Can anyone help me create a buffer using DAQmx in which the outputted data is sent in sequential order? Meaning the outputted data is taken in devided into 5 equal chunks of data based on the index number, so the output data needs to be in order.
Any help would be greatly appreciated.
Ryan
Ryan
LV 7.1
(2,892 Views)
I would start by looking at the shipping examples and do a search on buffered and select the search the Ni.com examples I found many examples for the 6110.If this does not help you try posting to the data acq discussion forum instead of labview general. I'm not trying to put you off but the enthusiast in that forum are outstanding because they specialize in that. Sorry I could not help you more.
Joe
Joe.
"NOTHING IS EVER EASY"
(2,892 Views)
