hex to binary
I've searched and found examples of exactly what it is I want to do, but for whatever reason, I'm not getting the correct values I want.
All I need to do is take a hex value...1F4EF5, and translate it into simple BCD so that I can take it apart at the bit level.  I'm currently following a few examples that simply take the hex string, convert it to an integer then to binary and I'm getting wrong results for the binary.  Any help would be appreciated.
(6,945 Views)
Accepted by topic author In-Use
Are you going for something like this?
(6,935 Views)
Hi crossrulz,
Mostly yes, except the output I would like to be a string that way I can search it.
-Ben
(6,863 Views)
Hi InUse,
why do you need a string to "search" it?
My approach:
(6,846 Views)
Hi Gerd,
String is needed or preferred rather because that is the format from the original vi that I'm modifying.  It's not necessarily required.  That said, I was able to use your example and now have working code...finaly!  Thank you to you two for the help.
-Ben
(6,835 Views)
You need to be very careful with the lenght.
For example if the first two digits of your input string are "00", you would get a short result with the given code. Maybe that's OK?
(6,813 Views)
