hex string value to floating point
As an additional note, I strongly recommend to study the documentation for this instrument. There is a non-zero chance that the first bit is actually a sign bit and that you should interpret it as such.
What is the temperature range of the sensor? Are negative temperatures allowed? Do you have a link to the manual?
Message 11 of 13
(1,006 Views)
Thanks for the consern but i think it wil be fine.
but sinse you asked
it is for a interface between central heating system and thermostat.
the insterface is built up form several divices
i go from
Thermostat e-twist (R-Bus Protocol)
to
R-Bus --> opentherm gateway.
from
Opentherm gateway is sending RS232 signals.
from RS232 to TTL converter.
and form TTL converter to a TTL / TCP interface. (configurd as UDP server).
and finaly reading the UDP singals in Labiew.
now i can readout parameters from the central heating system and respond on it.
main gool is beter Room temperature management.
not one temperature sensor in the room but now i have 4 temprature measurments in the room.
better and accured tempratue control
also i can combine a SolarSystem and in the futere a Headpump.
the problem with al the divices is they have all different communicanten protocols.
-Thermostat
-Central heating system
-PV pannals
-Solar System
-Headpump
sure all munufacturers hava a handy app but non of theese work to gether.
yes you have all sorts of home automation servers and smart home systems.
but they give me not the freedome i need to combine all these protocols.
i use Labview for my work as a elektrical engineers. and i always sa to my colleagues.
Labview is a powerfull software/hardware platform you can do anny thing you whant with it.
so i am developing my one labview appellation and read/write my one data and plot my one graphs
than i can dicide wat to see and control.
it will be a big project a it will take me some years but finaly i will controll all whit labview.
up to now i have implemented in labview:
-my alarm system (Siemens S300 (ethernet protocol) PLC and PIR sensors)
-several arduino and ethernet boards for hymidity, lux etc.
- solaredge Inverter (RS485 protocol)
-Philips Hue (LED and lighting)
-X10 protocol for more relay control in combination with lighting.
-P1 protocol (smart energy meter)
Mbus protocol for some flow meters.
and now i kan ad my central heating system
finaly i write the inportand data to a server (wamp and MySQL)
and read and control some stuf whit it.
so lots to do,  it is a intresting project and i learn a lot form it. 😊
it makes me a better labview programmer 😊
Message 12 of 13
(982 Views)
@altenbach wrote:
Note that you can also cast the U16 to FXP. same result, but a bit more dangerous and unsuitable for you math (e.g. linear fitting will coerce it back to DBL at the input)
I'd prefer the Integer to FXP cast. I don't know if there's any relevant difference.
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(798 Views)
