help with synchronizing data collection between LabVIEW Modules
I have a NI 9227 current model and a NI 9205 voltage module.  I would like to synchonize data collection between the two in order to obtain accurate I-V curves.  Any suggestions on the best way to do this would be appreciated.  Thanks.
(2,973 Views)
This will depend on task timing / chassis configuration.  What is your current chassis setup?
Alexander M
(2,951 Views)
I am using a cDAQ 9174.  Right now I have the two modules synchronized using the sample clock of the NI 9227.  But I have encountered a problem with this configuration.  Another thread that I started discusses my new problem:
http://forums.ni.com/t5/LabVIEW/Help-with-slowing-the-sample-rate-of-a-DSA-module-below-its/m-p/1795...
Any help you could give me to fix this issue would be immensely helpful.
(2,947 Views)
Synchronization should be fairly simple between two modules on the cDAQ 9174.  I would recommend using a single task / sample clock, referencing all input channels from both modules in your virtual channels VI.  Also, be check out a few Multi-Device / Multi-Function systems examples located in the NI Example Finder under the category Hardware Input and Output >> DAQmx >> Synchronization.
Synchronizing DSA, S Series, and X Series Devices With a Single NI-DAQmx Task
On a side note, please refrain from creating multiple threads on the same topic.
Alexander M
(2,939 Views)
I did not post about the same topic twice...the link that I mentioned in my reply is about a different topic.  This thread was generated because I was unable to sync the two  modules at the time at the time it was generated.  I am now able to sync the modules but my data acquisition rate (which is determined by the NI 9227 internal master timebase) is too high for my application.  I need to reduce the data acquisition rate by either averaging samples read by daqmx read or something similar.  Please point me in the right direction towards doing so.
(2,931 Views)
There are a number of ways to average samples in LabVIEW.  I usually recommend using the Mean.vi under the Mathematics >> Probability & Statistics Palette.  Otherwise the good old fashion 'sum all the samples then divide by the number of samples' would work just as well.  I would recommend post-processing or running a simultaneous loop to process the samples to avoid running into timeout errors with your DAQmx task.  Make sure to check out the examples in the NI Example Finder.
Regards
Alexander M
(2,913 Views)
