Error code XML file
When I use a custom error file xxx-errors.txt.How do I get the general error handler to choose the codes from this specific file?
I am not clear on what tells the vi to use this file.
Jim
(2,818 Views)
The file has to be in user.lib/errors.  Also you have to restart LabVIEW after creating or changing the file.
LabVIEW 2012
(2,817 Views)
Still a bit lost
If I had two error file File1.errors.txt and File2.errors.txt both in the user lib.
File 1 defines error code 5000 as a general fault
File 2 defines error code 5000 as communications lost
I want the VI to use the error code from file 2 "Communications lost"
How does labview know which file I wan't to use.
Jim
(2,808 Views)
All error files are loaded. If you have a duplicate code, both will be listed as possible reasons.
(2,802 Views)
