help in contour maps in labview
Just use the "Rate this message" buttons in the bottom right corner. 😄
Keep wiring !
CC
Chilly Charly    (aka CC)
Message 11 of 15
(1,783 Views)
You are welcome!
Ben
Message 12 of 15
(1,774 Views)
For some reason the color bar does not work? I attached a screen shot.
Message 13 of 15
(1,693 Views)
I didn't fully understand your problem.
Regarding the color bar, what i have done at the end is to adjust the colors at the 3D figure properties you have there an option to set the color with the value you want. ( I am at home right now so If you don't find it send me another message on monday and I'll send you an example)
and to so the color bar at the fonrt pannel I just made print screen , and criped the color bar from there. then I added the image to the pront pannel.
Hope it helps you
Eran
Message 14 of 15
(1,685 Views)
Okay, then I have miss understood the whole thing.
I was forwarded to this topic by somebody. So I will reactivate my topic.
Message 15 of 15
(1,682 Views)
