help !! animation icon created in Labview front panel
hi guys, thank you for enter here. becouse i faced the problem of creating the animation icon on the front panel of Labview. Have somebady can teach me how to solve the problem. My question is, i wanna create a GUI system on the front panel. A animation icon such as DC motor, when i give signal true to the motor. at the same time, the animated picture on the front panel also will be rotating. Have anybody know how to solve it and teach me the solution. thank you very much
(3,555 Views)
A picture ring is what you need.
I haven't used it yet, but I think the easy way would be to place a animated gif in there.
Felix
(3,544 Views)
Accepted by jeff7095
You can take a boolean control and customize the same.
1) create a new custom control
2) Place a boolean control/indicator
3) click on "edit->import picture from file" (motor not running picture) from the menu
4)Paste this imported image to the "False" case of the boolean by right clicking and selecting "import picture from clipboard->False" from the pop up menu
5)Repeat the 3 and 4 for the motor running picture
Guru
Guru (CLA)
(3,542 Views)
