hello everyone
how to Store the last measured value of the sensor in a variable
(992 Views)
Hi johnalia,
Use a shift register instead of a "variable".
THINK DATAFLOW: in LabVIEW wires/shift registers/feedback nodes are "variables"…
(978 Views)
can you please show me an example
(961 Views)
Go to ni.com and search. You can find many useful knowledgebase and documentation.
Using Shift Registers in LabVIEW
Control Lead | Intelline Inc
(944 Views)
... and next time please use a post subject related to the question. "hello everyone" is not a suitable subject.
(928 Views)
The last measured value is stored forever in the indicator connected to it and will only change when a new value arrives.
If you want to keep the previous value AND compare it to the newly measured value, use a shift register or feedback node as already suggested.
You can dramatically increase the chances of a useful answer if you exactly define the problem you are trying to solve and attach your code draft (a vi, not a picture).
(926 Views)
