hearing test
Hello everyone,
For a school project, I have to make a hearing test in Labview. This is my first time working with Labview so I don't have any experience at all. I've made an hearing test with little beeps in which the amplitude increases until someone hits the 'I hear the sound'- button. When this button is hit, the frequency changes. After this, the amplitude increases again until someone hits the button. This works quiet well, but I've got some little problems. I want to have an option in which the program terminates immediately. I've made this button in my outer While Loop. But if I hit this button, first the inner cycle in which the frequency increases has to be done. How can I stop my whole program with one simple press on a button? Another problem is that the amplitude increases with one step AFTER I hit the 'I hear the sound'- button. This has to be as well immediate, when I hit this button, I don't want to hear a louder beep with same frequency but a beep with another frequency. I hope you understand my questions. When someone can help me, my thanks will be very huge.
Yours Sincerely,
Maarten Willekers, Amsterdam, The Netherlands
(4,141 Views)
Hi Peter,
you should rethink your program logic…
Why not use just one while loop?
while
  play sound
  increment volume
  IF volume > limit THEN
    volume = 0.02
    increment frequency
  ENDIF
until STOP or frequency > limit
(4,130 Views)
Thanks for your reply,
I don't really get it still..:P So I have to make my program in one while loop. But I don't understand how to let the amplitude increase seperately from the frequency.. If I put both of these in one while loop, they both will increase immediately, don't they? Do you think you can make a small VI with the idea you got about it? Thanks very very much.. Deadline is coming near..:'(
Best regards
(4,109 Views)
Hi Peter,
did you notice that IF/THEN/ENDIF command? No, you don't increment volume and frequency with the same condition...
(4,081 Views)
