harmonic simulation with LABVIEW
hello everyone 🙂
So now I have a project this year which is based on the LABVIEW software, and I'm a bitbored because I have a worry in my program. I explain my problem:
I wanted to start my program in several harmonics using the method shown below join, using a table, except that this program does not work.
so I want to know if I can fix this program, or simply use another structure to launchseveral harmonic my choice (for example I want to launch five harmonics and thensimulate them by changing parameters in the frequency and amplitude of each harmonic)
Thank you for your help ^^
(2,901 Views)
Maybe you can use the following VI to generate differents harmonics:
Keep me update.
(2,857 Views)
