grounding/shielding problem, or something else?
Hi
I have written a program which utilises the PID tookit control the
temperature of a furnace. The program was written on a PC which had a
PCI-MIO-16XE card, attached to a SCXI-1000 box which contained SCXI-1102,
SCXI-1303, and SCXI-1302 module/accesories.
Now the program is finished we want to be able to put it onto another
computer, which has a different card in it. The card in the other computer
is a 6052-E which is connected to a CB-68LP connector block.
Since we have been using the new set-up we have been encountering quite a
lot of problems, which I think are arising from grounding or shielding
problems. We did have some grounding problems on the previous set-up, which
we cured by attaching the furnace to the GND pin of the SCXI-1303.
On the board we have a K-type thermocouple input, the positive lead being
connected to pin 65 and the negative to pin 31, and the channel called
"furnace". A LM35 temperature sensor provides the cold junction
compensation. A channel called "out" has been set-up as DAC0OUT, with the
positive lead being attached to pin 22 and the negative to 55. This provides
the input to the phase-angle board which powers the furnace.
The PID software uses the value from "furnace" as the process variable and
the output is sent to the channel "out". This set up has worked perfectly on
the previous computer, and we obtained temperature control of +/- 0.1 deg C.
In the new system, as soon as the power is supplied to the furnace, the
thermocouple reading goes extremely erratic (moving around by +/- 10 degs or
so), and the PID loop cannot control. This is where we get stuck - the
CB-68LP does not have just one GND pin, but several AIGND's, AOGND's, and
DGND's. Which one do we use? Are they all at the same ground-level?
We tried attaching our grounding wire to pin 55 (to make it have the same
ground as channel "out"). This helped matters quite a lot, and the
thermocouple reading no longer jumps about all over the place, but we are
still left with another problem. The PID loop still cannot control the
temperature of the furnace very well, and it oscillates around the
set-point. I have not changed the PID values which I obtained from the
previous set-up which gave very good control, and I don't think the
parameters would have to be changed just because we have changed computers
(I have tried changing them anyway, with no improvement). What I think is
happening is this.......
The thermocouple is not at the same ground as the furnace (which it is
connected to), and when power is put into the furnace a current is produced
in the thermocouple which distorts its value (it lowers it). So when the PID
loop decides more power is required, it increases the voltage output of
"out", but this actually makes the temperature apparently fall (because the
thermocouple value is being distorted), and so the PID loop puts in even
more power (because it is still trying to heat the furnace up). Eventually
it puts in so much power that the temperature reading finally begins to
increase. The loop then reduces the power to the furnace (because it can now
see the temperature rising) and the thermocouple reading is no longer being
distorted and the true value is given, which is actually much higher than it
was displaying whilst the power was being applied. This process repeats and
what you end up with is oscillations of several degrees around the
set-point.
We have tried to ground the negative side of the thermocouple (we tried all
3 grounds, AIGND, AOGND, DGND) and all this does is make the thermocouple
reading so noisy to be unusable.
Is it possible that we are suffering because the CB-68LP connector block is
unshielded? We did not have any of these problems when we were using the
SCXI set-up. Do you think we would benefit if we upgraded to the SCB-68
connector block which is shielded? Or do you think the problem I have
described is nothing to do with shielding/grounding, and the cause lies
elsewhere?
I am sorry this mail is so long, but I thought I should give you all of the
information!
Jon Atkinson
(3,723 Views)
Jon,
The first question I have is how your cold junction compensation IC is
connected to the acquisition board (what pins)? From what I can tell
from the E series manual, there shouldn't be any problem if you have
your inputs configured as differential.
A clear explanation of what each of these pins on the acquisition board
do is on the NI website. Get the manual for the E series DAQ cards.
That will explain what all the GNDs are.
Where I'm going with my thinking is whether the problem is with the
thermocouple or CJC. With SCXI, most of them have on-board CJC. If
the CJC voltage drifts and the thermocouple does not, the software
thinks the temperature has changed, so it would be beneficial to know
which end is causing the problem.
Mark
In article <941tmg$ou6$1@usenet.bham.ac.uk>,
"Dr Jon Atkinson" wrote:
> Hi
1102,
computer
quite a
which
being
the
provides
variable and
perfectly on
deg C.
the
degs or
and
same
are
computers
think is
produced
the PID
of
(because the
even
Eventually
to
can now
being
than it
repeats and
> set-point.
tried all
thermocouple
block is
the
68
lies
> elsewhere?
of the
> information!
> Thanks,
> Jon Atkinson
Sent via Deja.com
http://www.deja.com/
(3,723 Views)
In general, what you are doing should be fine if you:
insure that the thermocouple is isolated from all potentially conducting
parts
connect to A/D differentially ( you have already done this)
provide a balanced resistance path to AIGND from both legs of TC (100K Ohm
from each leg to AIGND) to prevent "floating" the signal outside the common
mode voltage.
set the A/D gain high enough to maximize the range of the expected TC mV
level (50 mV for example)
aquire multiple points and average or median average the buffer (like 1000
samples at 1000 samples/sec)
this should produce a stable reading.
you can collect both the CJC channel and the data channel continuously at
this rate and pick off the data in 1 sec blocks.
Since you have eliminated any ground loop by isolating the TC, you should
have a true signal.
I would expect the sample to sample variation to be less than .1 degree.
Stu
"Dr Jon Atkinson" wrote in message
news:941tmg$ou6$1@usenet.bham.ac.uk...
> Hi
which
provides
on
C.
or
produced
PID
the
now
being
it
and
> set-point.
all
is
> elsewhere?
the
> information!
> Thanks,
> Jon Atkinson
Stu
(3,702 Views)
The point is you have three optionsfor signal refence to ground.
1) AIGND, AOGND, DGND pins are exactly the same thing, i.e. the so called refenced single ended.
2) Ai-sense pin is for non referenced single ended.
3) The third way is differential.
The ref and non-ref single-ended are the same thing but referenced s.e. is connected to PC ground.
The first thing to remember is that hardware connections (cables and pins) MUST MATCH software configuration (from MAX and/or from within Labview). This can be tricky, especially when using high-level AI Vi's, which don't allow coupling settings, but use Max ground configuration, whose default is differential.
Anyway follow these rules:
a) use referenced s.e. (aignd) if your sensors don't have a ground of their own. This
way you'll have your sensor (all sensors!!!) referenced to PC ground
b) use non referenced s.e. (ai sense) if your sensors have a ground reference on their own and this reference is not the same of PC. Anyway remember that the voltage of signals MUST be within 11 V of PC reference.
c) use differential ONLY when sensors have different ground reference from each other and from PC. Remember the 11 V from PC!!(eventually use bias resistors as suggested in manuals).
Remember also that you can guess there's a ground loop if you see a 50 (60) Hz signal.
hope this helps
giovanni moschioni, italy
(3,702 Views)
