gray scale color table
I want to make a picture out of an 8-bit unsigned integer 2D matrix of data. I can successfully do that using the "draw unflattened pixmap" function. However, it requires a color map. If you don't wire the color map, it uses the default labview color map. I want to use a gray scale color map (numbers between 0 and 255 corresponding to colors ranging from white to black). I am not sure how to make this color map and implement it. I appreciate any help.
Message 1 of 10
(9,227 Views)
Make a 1-D array of U8: 0x00, 0x01, 0x02, 0x03, ..., 0xFF
George ZOU
http://www.geocities.com/gzou999
George Zou
Message 2 of 10
(9,220 Views)
Thank you very much for the suggestion. But I am not sure what the x stands for in 0x00 and what is FF? Is it hexadecimal? If yes, then what is x? I appreciate the help.
Message 3 of 10
(9,206 Views)
Hi Jahan,
yes, "0x" stands for hexadecimal numbers! Just right-click any numeric control/indicator/constant, select hexadecimal representationand the x is shown at the left border...
Message 4 of 10
(9,204 Views)
Thank you very much for the help. But still I am not understanding this correctly.
1)- First of all why hexadecimal?
2)- Second: I am using a loop to generate a 1D array of unsigned 8 bit integers from 0 to 255. I am using the loop counter "i" to do that. I tried to convert the loop counter to hexadecimal, but I was not sure how.
3)- Also, I could not get an 0x to appear at the left corner of a number after I changed the representation to hexadecimal.
4)- I did not find a function that takes a number and converts it to hexadecimal. I am using LabVIEW 7. Where is this function?
Sorry for asking too many questions. I hope you will have time to answer.
Message 5 of 10
(9,202 Views)
I don't think George had any particular reason. Sometimes it's just easier to represent numbes in hexadecimal format. It's still the same number, it's just displayed differently. Hex FF = decimal 255. Same number.
 You don't need to do that. The values of the numbers is what's important, and as I indicated it will still be the same whether you display it in decimal or hexadecimal format.
 You need to enable the "radix" display. When you right-click on the constant or control and select Properties it's on the Appearance page, marked "Show radix".
There isn't one because there's no need to do so. The value of the number doesn't change. There are, however, functions to convert from/to hexadecimal strings, but that's something different.
Message 6 of 10
(9,185 Views)
Message 7 of 10
(9,178 Views)
The part about making each R, G,and B values the same is what was missing from George's response. Yes, to get a grayscale color map you can just have a loop to generate the 256 entries and use the RGB to Color VI to get your color by setting the R, G, and B values to the same value (i.e., the iteration loop). Is there a better way? Well, I suppose you could just have the resultant array as a block diagram constant. That would eliminate having to generate it "on the fly".
Message 8 of 10
(9,162 Views)
Accepted by Jahan
Jahan wrote:
Yes, this is technically correct (top). (Typically you can do it once, then right-click the indicator and "change to constant" and delete the loop code.)
You might also flatten the rgb tool code to the diagram (bottom). This has the advantage that the entirel loop will be calculated once at compile time and internally folded into a constant so the loop actually never spins during execution of the program (See also). (Of course this particular loop is trivial and nothing to worry about, performance wise. ;))
Message Edited by altenbach on 03-14-2009 09:57 AM
Message 9 of 10
(9,157 Views)
Thank you all for your help and suggestions. I will do the constant array trick to eliminate extra spinning of the loop. Cheers. On my front, I consider the problem solved (for the time being):smileyvery-happy:
Message 10 of 10
(9,146 Views)
