graphics area
I want calculate the graphic area and to found tips in the graphic leaving of points in the file, using the Labview. There some algorithm or function for this in the Labview?
Please can someone tell me how to do this ?
Many thanks
Edimilson.
(2,997 Views)
Sorry, but could you be more specific ? What graphic area are you talking about ? Which file ? What is the leaving of a point ?
Are you trying to find the surface area of a polygonal shape, somehow star like ?
Chilly Charly    (aka CC)
(2,968 Views)
I have a set of points in an archive ".txt" that, to the being located in the graph, it generates a curve, as for example a sine one.  I want, to leave of these points, to find the peaks that have in this curve and later calculating the area formed for this curve.
Thanks you!
Edimilson
(2,968 Views)
Search for "Chromatography" or "Peak Integration", using the Advanced Search. Do not forget to select "any time". There are plenty of usefull threads on the subject, with potential solutions to your problem.
(2,954 Views)
