02-01-2009 12:25 PM
I have a series of voltage values like (12 10.9 10.8 10.7 11 11 11 10.8 10.7 10.7 10.9 11 11 12) on the y axis. Everything that is less than 10.9 is consider to be a voltage drop and I would like to find the time of the drops. As you can see there can be more than one voltage drop, and I have to get the time for every drop.
Sorry for my bad english, and thank you,
Stefan
02-01-2009 12:50 PM
hello ,
here a little example,
tell if this works for you
Best regards
Tinnitus
02-01-2009 01:33 PM
Sorry the same with filled arrays
02-01-2009 03:26 PM
Could you save it for Labview 8.2 :), only if that is not a problem.
Thanks a lot,
Stefan
02-01-2009 06:17 PM - 編集済み 02-01-2009 06:22 PM
here in 82
best regards
02-02-2009 10:15 AM
Regarding this values ( 11 10.8 10.7 10.6 10.9 11 11 12), I need to get the time elapsed from the first value less than 10.9 and the last one (e.g. a drop can last more than 1 sec.) and there are more than one drop. So the question is, how can I see the exact time elapsed from the begining of the drop and the end of the drop.
Thank you for your time,
Stefan
02-02-2009 11:06 AM
sorry,
it's not what i understood first
02-02-2009 03:24 PM
Hi Stefan,
I think for this you could just keep track of when you go from a value greater than 10.9 to a value less then 10.9 and then write the value to the array, likewise when you go from a value going from below 10.9 to a value above 10.9 and write that time to the array. Then you can do something like subtract cell 0 from cell 1 to get the time period of the first dip, etc for the following time periods.
