graph with old data points from file
I have a training device with sensors, arduino microcontroller, and everything is processed in labiew, and shown on the interface.
I have data saved into a file (coma seperated values), where the kg of reputations is saved. For example, 1kg, 2g, 1.5kg, 1.7kg, etc, everysecond.
I wouldlike to make a new graph, with x->time, y->weight. This will show the exercises, because the person stands on the measuring board, so when he pushes 10kg more than his body weight, its visible on the graph.
BUT i would like to show the last tranings somehow also, so it is more motivating that you can see your improvement. I attaching a picture about the graph: graph_labview.jpg
My problem: how to show the calculated maximum from more files, and show it on the graph? For example like a line, shown in the picture. I also have problem that how can i read from a file, when there is multiple collums, to calculate the maximum. I attach the current data file from what i need the maximum kg value: test1.txt
Any suggestions?
(2,763 Views)
Hm, you could add those horizontal lines in form of (free) cursors. However, having a time relation for these lines (e.g. "When was the maximum") is not recommended but it seems that you already are aware of that....
Norbert
EDIT: Depending on the variance, you possibly have to deactivate auto-scaling for y-axis. Use programmatic scaling as required.
Norbert
Expert: Geometry
(2,740 Views)
