getting the highest peak
Hi everyone!
I'd like to know how to choose the highest peak like from the graph. Can anyone show me how can this be done?
Thanks!
(3,976 Views)
What is the datatype (array, waveform, dynamic, etc)?
If it is an array, you can use Array Max&Min.
(3,972 Views)
You might check out Peak Detector VI.  This library function lets you specify a threshold so that only peaks over the threshold are returned.  You can also specify a minimum width for peaks as a simple noise filter.
(3,963 Views)
It is really difficult from the image to even tell how the peaks looks like. You have many, many plots on this graph (many colors!) and there is huge overlap, especially in the middle. Can you zoom it to show how the pile of peaks in the center actually looks like? (... or even attach the VI containing typical data).
(3,956 Views)
The input is a 2D array. But I want to extract the highest plot and plot in another graph.
i can't attach the VI because it has some hardware dll in it and this is the zoomed in version of the graph before. (The x and y axis are different because I adjusted the hardware a little)
(3,946 Views)
Accepted by topic author Enriquez
As Altenbach said: Array Max & Min.
For 2d arrays, it returns row and column. Use the row:
(3,940 Views)
