I don't recognize *IDT? as 488.2 common command. There's a *IDN? and an *IST?. Did you enter the correct command because this error usually happens when there's not dta sent back, as would happen with an invalid command.
You can use the instrument driver available
here instead of trying to use the I/O Assistant. After downloading, unzip it and move the folder to your instr.lib folder. The next time you start LabVIEW you should have the driver on your Instrument I/O>Instrument Driver palette.
